doriswneil
50 points
Posted on - 05/24/2013
Hello fellow members. I use Avast Antivirus on my Windows XP 64 bit system. I recently performed a scan and it gave an error report. How do I print screen of Avast Antivirus Error Report? Any help would be much appreciated. Thanks in advance for the help guys.
How do I print screen of Avast Antivirus report?
Hello Doriswneil. What do you mean by print screen? If you just want to print screen the report, as in capture the image of the screen, then just press the 'PRTSC' Â on your keyboard. Open any photo editing software such as Photoshop, or even Paint will do. Paste the image, or press Ctrl + V. Then save it as any image format you want.Â
Hi Doriswneil,
I did not really comprehend your question but from what i understand is that you what to print the page of your error report.
If you already have a printer installed directly to your computer then just lunch the printer on that page by using the short cut which is Ctrl P and then proceed directly to the printer wizard or you can as well try to copy the page either by using the mouse or the keyboard short cut which is Ctrl C then paste it into a Word page which will then facilitate your printing process.Â
Hope that could help.
