How do I process iPhone applications?
How are iPhone applications processed and what are the requirements? What are the chances of getting approved and what are the reasons for disapproved applications?
Hi there Elaine!
To be able to process your iPhone application, you can use the iProcessing. With iPorcessing, you can publish or prototype iPhone applications. This is very great for those who are starter in processing iPhone applications. iProcessing is an open framework programming to help everyone create or develop iPhone applications. iProcessing uses processing language and it uses java script to create iPhone application. There maybe some problems with iProcessing like limits to speed and graphics but this is better than openframeworks. Once you have processed your iPhone application, you can now submit it to App Store. For more information, please visit the link below:
http://luckybite.com/iprocessing/
-Zorian
