techsavvy08
10 points
Posted on - 06/14/2012
While I am searching the net, I saw this article about the Rascal Micro. What makes the Rascal special is its integrated Linux kernel ROM, Micro SD slot, Ethernet port and the duo of USB jacks.
But how am I going to program and use the Rascal Micro?
How do I program and use the Rascal Micro?
Windows XP:
1. Download the Trend Micro Diagnostic Toolkit as the link given below
2. Click Run when the File Download window appears.
3. The Trend Micro Diagnostic Toolkit window appears after the download finishes.
4. Click the Uninstall tab, then click 1. Uninstall software.
5. The Toolkit will automatically detect the Trend Micro program that is currently installed.
6. Click Uninstall.
7. After the program finishes uninstalling, you will then be asked to restart your computer.
8. Click Yes.
Windows Vista or Windows 7:
1. Click your Windows operating system version below to download the Trend Micro Diagnostic Toolkit.
3. The User Account Control window will appear.
4. Click Yes.
5. After the download finishes, the Trend Micro Diagnostic Toolkit window appears.
6. The Toolkit will automatically detect the Trend Micro program that is currently installed.
7. Click Uninstall.
8. After the program finishes uninstalling, you will then be asked to restart your computer.
9. Click Yes.
