Hi.
I just installed BSPlayer Pro Version 2.63 to play my OGG and DivX media files on a Windows 7 64 bit system.
How do I put BSPlayer admin privileges on the player when it starts up?
Any help would be highly appreciated.
How do I put BSPlayer admin privileges?
That’s simple.
Simply right click on the BSPlayer shortcut then click Properties. A window will pop up, click the Compatibility tab, then look for the check box below which says ‘Run As Administrator’.
Check/Tick that then click Apply or OK to close the window.
After you have done these steps try opening the shortcut again it is now running as administrator.
Hi Richard
Thanks for posting your solution here. Set privileges from the application can sometimes be accessed unauthorizedly by any person having little knowledge of CMD. But here i am giving you a software link which can be installed on the pc. It protects any application from any user by acquiring passwords.
It is good way to use third party software to reduce the risk.
http://softwaretopic.informer.com/bs-player-administrative-privileges/
Hope this will work for you.
Floyd
