How do i put security on my nokia c3
I just got a my mum a new Nokia c3 but I don't know how to install the security codes on the phone so that her information is safe. How can I help her?
Hello Quiqui ,
First of all the security on the phones is very diverse from Keypad Lock to GPS Locking. Nokia C3 provides the user with the basic security features, Which allows you to lock the keypad to unable others to access the phone options. Here is a detailed overview for locking up the Phone's keypad:
1. Go-to Menu > Settings > Phone > Security Keyboard and turn on this selection and exit from there
2. Now Go-to Menu > Settings > Security > Security Level and select phone. It will ask for a Security key which is by default 12345 but you can change it as you wish. Press Ok after altering it.
3. You're Done ,Whenever someone tries to unlock the it'll ask for the security key and entering it will provide access to the phone
Hope it helps,
If you have a Nokia C3-01 handset, here’s how to setup the security code to protect your phone. On your phone, go to “Menu”, “Settings”, “Phone”, and then tap “Security keyguard”. Tap “On” and enter the default security code without quotes “12345”.
Once it is activated, you should change the default security code. Again, go to “Settings”, “Access codes”, “Change security code”, and then enter the default security code without quotes “12345” then tap “OK”. After this, enter the new security code and then tap “OK”. Enter the new security code again to verify then tap “OK”.
Here are the phone’s specifications for additional information. The Nokia C3-01 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on September 2010 and released on October 2010. This phone has been discontinued. It measures 111 x 47.5 x 11 millimeters and weighs 100 grams. It uses mini-SIM card.
It has TFT resistive touchscreen display with 256K colors at 240 x 320 pixels screen resolution. It runs on 680 MHz processor for the RM-640 model and 1 GHz processor for the RM-776 model. It supports microSD expandable up to 32 GB. It runs on 64 MB RAM with 128 MB ROM and 30 MB internal storage.
The primary camera supports 5 megapixels with LED flash and can record video in 480p at 15 fps. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n, Bluetooth 2.1 with A2DP support, stereo FM radio with RDS support, and microUSB 2.0. The preinstalled web browser supports WAP 2.0/xHTML and HTML with Adobe Flash Lite. Java is supported via MIDP 2.1.
It runs on removable BL-5CT Li-Ion 1050 mAh battery with standby time up to 405 hours on 2G and 440 hours on 3G. Talk time is up to 5 hours 30 minutes on 2G and 4 hours on 3G. It is available in golden khaki, silver, and warm grey colors.
