alex baker
30 points
Posted on - 09/23/2014
I would like to record some of my gameplay on my Xbox One. I have had a quick look online, but all the solutions I have found so fare are targeted at Windows OS.
Are there options for Mac users?
I have a MacBook, and I am looking for a program that would allow me to record gameplay and maybe do some minor editing. Does such a program exist for a MacBook?
How do I record Xbox One gameplay on a MacBook?
You can record your Xbox One gameplay using capture tools available on your console. You can then edit that file with your Xbox One. Then you can place the file in cloud storage. Choose any editing software you wish for use on your MacBook and then access your gameplay file in the cloud. You can also use dedicated hardware for this specific purpose (gameplay capture). Use a search engine to find a device to your liking and specifications.
