How do I recover admin ISO password?
Please help.  I can't remember my admin log in password.  I'm on a Windows XP system and I already have the ISO image.  How do I recover admin ISO password?  I need step by step instructions as I am not that technical.  Thanks in advance for the help.
Best Answer by Harrington Curtsinger
Answered By 0 points N/A #145707
Hi there Douglas, I kept on searching alternatives for your concern but it seems that the best way for you to access your account is to reset your password. Kindly visit windows recovery website to know more about how to recover your account.  There you will be provided step by step procedure on how to process it.
Answered By 0 points N/A #145708
Hi Douglas. Regarding on your queries on how to recover admin ISO password, You can download a software called SysTools, It helps you to reset Windows admin password easily and with a few simple steps you can recover your admin password. You can go to their website for the step-by-step procedures regarding on how to recover your admin ISO password. You can simply go to systools group for the step-by-step procedure. I hope it helps you regarding with your queries.
Answered By 5 points N/A #145709
You should download and install any available password recovery tool in the market. One available utility tool that may aid you in recovering your password is Cain & Abel. This is a very efficient and very fast utility tool for recovering your Windows password. You just need to be on Administrator account. It works on Windows NT, 2000 and XP. And supports up to 10-character password.
