How do I recover Intel program Easy Plan 2010?
A Win32 Trojan virus deleted some system files including my Easy Plan 2010 calendar planner.  How do I get back or recover Intel program Easy Plan 2010?  Need help asap as I use this calendar planner for managing and scheduling all my appointments and events.  I'm on Windows Vista 32 bit.
Answered By 20 points N/A #158980
Hello Bolton
You can download this utility for free from the Intel website. I will provide you the link here, just click on it and then click on Download Now option, the file is approximately 40MB.
But I would suggest to clean up your PC first to get rid of any viruses because it will then create problems with the installation process. Use any antivirus available in the market to clean the Trojan Virus. For Vista system I would recommend installing AVG antivirus, Kaspersky or Nod32.
First remove the virus, then click on this link below
Intel Plan-2010
Scroll down and click on Download Now button. Download and install it.
Hope this will resolve the issue.
Thanks
Bennie
