mr_poe
220 points
Posted on - 04/28/2011
I had accidentally removed all my files after reinstalling Windows using my factory restore CD. Is there any way that I can recover my deleted files on my computer?
These are so important, so I need to get them back.
How do I recover my accidentally removed files?
Yes, there are some ways to retrieve data that has been removed from a computer system. Once you have deleted your files, they will automatically go to the recycle bin. So, you must first check your recycle bin to see if you can find the data there.
mr_poe
220 points
What if I deleted those files in the recycle trash folder? Or, should I say that I also reformatted my hard drive?
You might as well try a couple of recovery software that we have. You can try this site, hope it will work for you.Â
Or else, you can search a different kind of professional software available and downloadable for free on the Internet.
It depends also with your system compatibility. I knew it because I used to download the free software before and it doesn’t work for me, unfortunately, I’ve lost my files. Now, what I am doing is to back up all my data on my PC using external disk.
You should also check the file settings which will show you what files can be recovered. Because that application has worked for me in the past, I have recovered my deleted files so fast and I downloaded it for free.
mr_poe
220 points
Thanks for your input. I have already downloaded the given site and will try to install it. Hoping that I will be happy with the outcome. So that I can recommend this as well to my friends who will encounter the same problem.
