Hi guys. I'm trying to register my ESET NOD32 Antivirus 6 using ESET Live Installer but I'm always getting an "Error 2878" message. How do I use and register ESET NOD32 offline installer? Please help. I'm on Windows 7. Thanks in advance.
How do I register ESET NOD32 offline installer?
Hello Elijah
There are a couple of reasons for your situation. Firstly make sure you are using the right product key. That is, the registration key before completing installation and also make sure your software is not corrupted especially if you purchased and downloaded it online.
Secondly make sure you are clicking on the right link in relation to where you got the software. If not, select the right link and continue installation. In case you are have an eMachine or Toshiba brand computer, there might be another antivirus speck in your computer that is causing the error. Uninstall the Norton Internet security if you still have it in your computer. By going to your computer’s control panel and click the add or remove programs. From which you will select Norton to be uninstalled. Further go to the programs and features in still in the control panel and choose and uninstall Toshiba Laptop by Symantec. You can the restart your computer, download a new live installer to be effective and begin installation again and if error appears click ignore and go ahead. Hope this helps you.
