How do i reinstall Windows vista?
I need help! I booted and put CD software in and it still didn't work. What am I doing wrong? It took me 7 hours to do.
Re-install from inside computer, or re-install from factory Recovery disk. Try it.
I did all that and still it didn't change. I still have Vista 7 on my PC and can't get in to it. It still says no drive when I try to sign in. Can I put my Windows XP on it? Â Like that better anyway.
If you got the Windows XP factory restore disk. Try that. It might work.
Put the Vista restore disk in the computer drive, reboot the PC. If it does not automatically boot from the CD, you may have to select the option right after boot start-up. Look for an option for one time boot device or boot menu on the black or blue boot screen. You may have to select Setup or BIOS from the boot menu and change the boot order, making the DVD drive the 1st boot device.
I did that and I still have Vista on and can't get in. Should it show that I am downloading or something? Can we go through this step by step I must be doing something wrong.
Go to search. Type download. If vista has been downloaded, it should be in there.
Thank you all for your help. There were 2 passwords I had to use. I forgot the first on and found it.
Put the CD into the CD-ROM. Then restart your PC and boot the cd from the CD-ROM. It will ask you to press any key for boot from CD. Then press any key for one time and let the windows vista to work on installation. I am sure it will help you, try this.
