How do I remove applications from symbian
Hey,
I have a Nokia 6600 mobile phone. Upon reading the manual, I discovered I should be able to simply select and remove applications from Symbian, but there is not a remove option. Can anyone help me?
Hey,
Hi Michael,
Here are the steps on how to go uninstall applications from your Nokia 6600:
1) You just have to go to Tools and then go to Manager application.
2) Select the application you want to remove. Go to Option then select Remove.
3) If you still cannot remove the application using Manager, go and select the entire directory C: or D:, depending where the application is installed., then go to System, then Apps, and then delete the directory of the application you want to remove.
4) Go back to System to install and remove the system files of the application.
