How do I remove ashampoo toolbar 2011 version?
How do I remove Ashampoo toolbar 2011 version? I've installed it and it automatically created a toolbar. I uninstalled it so that I could have a newer version installed and I'm having error from a "conduit engine".
Answered By 0 points N/A #135386
Hi Isabel,
You can try to remove from Control Panel > Uninstall Program (win 7) or Add Remove Program (Win XP) > find MyAshampo toolbar and click remove.
Or
You can use Ashampo Uninstaller.
Or
If you use Mozilla Firefox you can deactivate the add-on.
Click Tool > Add-ons (Crtl+Shift+A) > Choose tab Extension > Find MyAshampo Toolbar.
You can disable it or remove it.
If you use Chrome
Click Tool > Extensionb > choose tab Extension > Find MyAshampo Toolbar.
