I accidentally installed a power technology toolbar on my web browser. How do I remove power technology toolbar from my web browser?
How do I remove power technology toolbar from my browser?
Hope you are having a good day except this trouble. The main part is the browser.
What web browser is being used by you? Chrome or Firefox?
If you are using Google Chrome,
You need to click this browser’s menu button on the browser toolbar.
Then, you need to go to Tools and in the second popup window, go to extensions.
Beside each extension, will see a trash icon. You have to click the trash can icon by the extension’s side you want to completely remove from your browser.
When you click, a confirmation dialog will appear. In the dialog box, click Remove option. If you are using Firefox browser,
You need to click at the top of the Firefox browser window. There, you have to click on the Firefox button (Tools option in Windows XP), and then you will have to click Add-ons. Then, Firefox’s Add-ons Manager window will open. Here, you can manage any extension that is installed on your computer.
There, in the Add-ons Manager, select the Extensions or Appearance panel. This will depend about the extension. If it is an extension, you need to go to the Extensions. If it is a theme, then you have to go to Appearance panel.
On the next step, you have to select the add-on you want to uninstall.
There, you will have to click the Remove button to uninstall the extension.
After removing is complete, you have to click Restart now if it pops up. Your browsing history will be saved and restored after the restart.
Cheers. Hope now you will feel no more problems.
Please follow these steps to remove the toolbar.
Go to start and then to Control panel
Select Add remove programs
Find the desired tool bar you need to uninstall and click it
After that click uninstall and you will be able to uninstall it. If this doesn’t works then you can go to your browser settings and form there you can easily do the same thing.
Smith Thompson
