How do I remove a windows time stamp?
Hi guys. I want to increase the performance of EWF in an NTFS file system and someone told me to just disable or remove a windows time stamp. How do I do this? I'm on Windows XP 64 bit sp 2. Thanks.
Hi Richard B Garon,
To disable Time stack you should just follow steps and then you can easily do it. Just follow the instruction which is given in the picture-
Just right click here then you will show Properties:
Here a window where all of System icon is "On"
Just "Off" all of them
I think you these pictures will helpful to you to disable time stack.
Have a good dayÂ
Hi Richard,
Please do following to disable or remove a Windows time stamp.
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlFileSystem
NtfsDisableLastAccessUpdate
REG_DWORD
Value: 1
Generate the above registry key on your run-time image
Please refer to following links for better understanding,
http://www.microsoft.com/windowsembedded/en-us/developers.aspx
http://go4answers.webhost4life.com/Example/ewf-ram-reg-necessary-ntfs-sudden-179910.aspx
Hope this helps you.
Thnaks,
