How do I rename a mind map file on iPad?
I intend to rename a mind map file that is on my iPad. However, every time I attempt to rename the mind map file on the iPad just freezes and takes me back to the home view of the iPad.  The name does not change but colour label is applied. I am using Dropbos as the sync service. Please enlighten me on how to rename the Office 365
Answered By 55 points N/A #115544
-Have you installed any extra widgets on your iPad? Because all these crashes occur when you have installed few widgets through cydia.
-You haven't told which mind map software you are using so i am assuming that you are using Mindjet for iPad which is available for free in the appstore. There are few things you can try.
-Forget the mindjet and start using Xmind. It is a great tool which supports all the mindmap files from all other softwares. So there is no problem in switching from Mindject to Xmind. In Xmind, you can rename any file you want, edit it and even save it in another format of your choice. These all things make it an ideal choice for your
– apart from above, you can also try downloading freemind mapping software.
