How do I repair 3gp format header?
I was recording video in my Motorola RAZR V6 Maxx with a 2 MP, 1600×1200 pixels camera.  I transferred the 3GP output file on my PC and played it on VLC media player.  I am having a "3GP header is corrupted".  How do I repair 3GP Format Header?  Thanks.
Best Answer by Walsh Dipasquale
Answered By 0 points N/A #165691
Hi. Disoja Jully,
I am interested fixing you error. You can use advanced Outlook PST Recovery software or to repair corrupt 3gp file header or DOCX Repair 3.0 or corrupt PST repair 3.2 to fix your errors. Just download by using the link.
You can download them by using the following link.
I hope this will solve your issue.
Thanks & Regards,
Gillam Janetj
Answered By 0 points N/A #165692
HI,
If your video file is corrupted then you can use Video File Repair software to fix it. This repair software repair corrupted data from FAT16, FAT32, HFS+ and HFSX file systems. This video repair tool can repair all most popular video files like AVI, MP4, MOV, MPEG, MPG, M4V, 3G2, 3GP, RM etc. It also helps to fix streaming error. You can download repair software from here.
Answered By 590495 points N/A #311190
If that’s how your recorded video ends up, first, try uninstalling VLC media player then install the latest. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your VLC media player among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the latest VLC media player and install it. See if this works. If you get the same error after doing this, try converting the video.
Try downloading the free trial of ImTOO MPEG Encoder and install it. Convert your 3GP video into another format then see if it plays in VLC media player. The trial version allows you to convert five minutes of the video. If your video is longer than that, you probably need to try other converters.
