How do I repair a cyclic redundancy check data error?
Answered By 0 points N/A #81224
This might mean that the file is read by its PC or software is damaged.
My suggestion is the first recommendation that will be to copy the file to a different disc completely, or a machine different from the local network.
'The problem can be a hardware (free cables, it is missing of unit (unity)), software or damaged the mass media.
In most cases, to verify and to clean the disc is the form easiest to overcome the problem.
If it cleans the different discs they produce the same error, it is probable that it is a problem of hardware (Verify the discs in another unit (unity)).
Another common cause of these errors is burned badly CDs and DVDs – especially to that there were numerous ones or buffer severe under runs.
Answered By 590495 points N/A #81226
I’m not really sure if a file with a Cyclic Redundancy Check error [CRC] can still be repaired. A file with a CRC error can also be considered as corrupted because usually the file at this stage is already inaccessible or if it is an executable file the program will not run when you attempt to launch it.
This kind of error happens when a file is stored in an area of the hard drive where there is a bad spot or a bad block. You may try using data recovery software and or a disk repair application and hope that one of these tools is the solution.
That’s why it’s important to have a regular check or maintenance on your hard drive using disk repair software or any hard drive diagnostic application so you would immediately know if your hard drive has developed a bad sector. The disk utility software can immediately mark the bad spot as bad block to prevent any files from using it.
The fact that you're seeing it when you try to copy a file indicates that the bad sector is within the file itself.
For more information, you may visit How to fix CRC error.
Answered By 10 points N/A #81227
Hello K. Walibora,
As well these techniques you can also check another technique which is described another Techyv page.  Check and get more idea about Cyclic redundancy check data error.
Data Error Cyclic Redundancy Check (CRC)
