How Do I Resize My Photograph?
I want to use a photo of mine in an online form. The form is asking it to be in a specific size in terms of pixels. How do I resize my photograph?
Online forms for different portals have some specifications related to photographs. Resizing of photos is possible in many ways. Out of these Paint is the simplest one and is readily available with all versions of Windows. Follow the following steps:
1) Take the cursor to the photograph and right-click on it.
2) Select Edit.
3) It will open it in Paint.
4) Press Ctrl + A. This will select the whole image.
5) Press Ctrl + W or select Resize from the panel above.
6) Select Pixels.
7) Type in the number of pixels you want vertically and horizontally.
8) Do not forget to tick mark the Maintain Aspect Ratio field to save your photo from getting flattened or elongated.
9) Click on Ok.
Notifications
