Greg Lewis
40 points
Posted on - 04/24/2013
Hallo! I am running my server on a powered by vBulletin computer system and I have been having issues with the applications that run on the server. Every time that I store files on the server I realize that something happens and the files duplicate. This even happens to the folders that are stored there. What could be the problem with the server? Thanks a bunch.
How do I resolve file duplication in vBulletin Computer system?
Hi Greg Lewis:
Check for viruses in your computer. Some viruses disguise themselves as a duplicate folder or file. You may want to also check the folder locations of the files you are saving. Make sure to just use one folder in your download manager if asked where you want to save the file.
Also, you may use a duplicate finding software. You can download them. These kind of software may not be available for free. Here is a list of available software you can choose from:
Duplicate Images Finder
Easy Duplicate Finder
DoubleKiller
