How do I restore my e-mail contacts?
If you can access the services of Yahoo but unable to go to Yahoo Mail. Then don’t worry there is may be some problem with your Yahoo E-mail account.
If yahoo is continually asking for password verification while your email ID is displayed, then please try the following steps to resolve this problem:
You provide the correct password and tried to sign in yahoo but not successful. Click Sign In at the top left of page. If you're taken back to this page, you're properly logged into Yahoo.
If you are logged in on another page, then the problem is not with your Yahoo password. Then there must be a problem with Yahoo Mail account service.
Your password is correct and working on yahoo you don’t need to change it because changing your password will not resolve the issue.
This problem may automatically resolve after some time.
Hello there!
In Google mail, there is an option that allows you to revert your contact list and undo any mistakes made up to 30 days in the past.
It is called the Restore Contact option.
Enjoy and Good Luck!
First of, you'll need to have your password reset. Since you forget your password, then you need to create or need to get new one.
Log into webmail and click on the forgot password link. This will ask you a security question or a challenged question. You need to answer the questions and if you provided the correct answer, then a new password will be generated and displayed on the screen.
You should be able to log-in and personalize the password afterwards. You'll need to go to your list of contacts and it'll display all of those contact lists on the screen. It'll only display what's been saved on your contact list, otherwise it'll be gone.
Some email providers have a feature to recover all your contact list in certain days. Gmail has it for 30 days recovery and Yahoo mail has it too.
To restore email contacts, go to select file and import and export on the menu in Outlook.
After that, select import from another program or file and click next.
You can see the Highlight Personal folder file (PST), click next again and use the browse button to select and copy the PST file, if you want to recover from the backup location.
You must replace the duplicate with the items imported in the selected and click next.
Start import process now.
Hi sharathr!
Thank you for the information.
I got my new password after it has been reset. Never thought that It can be done this way.
Before I always get to lose my password and I keep on making new accounts because of this case.
I have learned something today both password and contact recovery.
Thanks so much.
Cheers!
Excellent Job done by all the author but Sharath Answer suits best Really useful information.
It helps me to clear my doubts.
Thanks for all the solution providers.
Hi Pa21l
Check out this Techyv post too "Restore Deleted Contacts in Outlook 2007" to get more techniques to resolve this issue.
