How do I setup wordpress in ubuntu?
I am running Ubuntu 10.10 on my pc and want to setup a WordPress site on local host.
I have MySQL, PHP, Apache server installed.
Could anyone provide step by step guide?
Here is what you need to do:
I cannot paste the folder inside www folder.Â
The paste option is greyed out. Ctrl+v does not work either.
What can I do?
Open the terminal and type "sudo nautilus".Â
Type your password. A new window will open with root access.
You can copy whatever you like.
One more thing, if you are on a Linux system, you should try to make yourself comfortable with the terminal. Nautilus is the way to go with beginners i agree but in the long run, you will have to come to the terminal. For example you could copy paste files using > sudo cp file1 file2. Here's a good way to start, set this as your wallpaper.
It was high time someone told me this because I was starting to feel the same way too.
The terminal and its powers fascinates me but it makes me nervous at the same time.
Great upload though, I guess it will help me a lot while setting up WordPress.
Thank you bug_fix!
