anonymous
7060 points
Posted on - 11/10/2011
I am having problems sharing a calendar between a Windows user and a Mac user. When the shared calendar is open in Mac, there is no way we can pick a specific calendar aside from the primary one?
The Outlook 2011 does not permit adding shared calendars to your own view.
Even when the Windows user is invited.
So I don't think that it's an issue of permission because the calendar opens up in OWA on Mac without problems.
How do I do this in Outlook 2011?
How do i share calendars with servers
Hi Abbiegail,
Your right your problem is not based on the issue of permission in sharing calendar between windows user and Mac User. What I suggest you to do is you have to update your calendar to a MobileMe Calendar. This application can be used by an iPad, iPod touch, iPhone, Mac and PC user.
What are the services it an do?
Can share calendar with friends and family.
Can publish calendar for a team or a group.
Can make event invitations through RSVP
Can be the most ideal calendar suit for iPad, iPod touch, iPhone.
Can make a another web application
MobileMe Calendar utilizes CALDAV system in which it can enable the user to see and manage their calendar having a built in calendar program on their unit. or vice versa the window user can manage their calendar though Outlook which has a MobileMe Control Panel for it.
Hope this might help you
Thanks
