How Do I Solve The Error Which Says, “Camtasia Studio Cannot Complete The Production Of This Project” Please Help.
I have a Windows 7 PC. I am using the Camtasia Software. I was trying to make and complete a project on Camtasia. But I keep getting an error. The error says, “Camtasia Studio cannot complete the production of this project.” Please help.
Answered By 35 points N/A #289917
Locate the file that was mentioned in the error dialogue box. I am sure that is the place of origin of the error. Please try to open this file. You can also play this video through Handbrake.
Now, reopen the Camtasia application. Locate the file mentioned in the error on your timeline. Right-click on it, click on the option to update media and replace with the new file you had produced using Handbrake. The error must not come again. Try to do whatever you were doing earlier, and everything should work fine.
Hope this helps!
