How do I start Visual Paradigm?
Hello experts
I am using the first release of JRE. I would like to know how to start Visual Paradigm on it.
When I try, I get a blank screen.
Can somebody please help me with this one?
Thank you.
Hello experts
Thank you.
Hi good day!
I hope I can help you with your problem.Â
How to run Visual Paradigm with the Original JRE.
a. ALT + F2 to get the run application dialog box.
b. Run meatcity – replace(you should type this to the empty line).
c. Run VP.
1. At first run you will need to install a license key (see home page
d. Re-enable desktop effects.
1. Alt+F2 to get the "run application" dialog box.
2. run "compiz "-replace (you should type this in empty line.
