How do I stitch a movie together for Windows
My cousin sent me 3-part movie videos of his wedding. The whole family is going to watch it in my Windows PC. I want it to be continuous as no one knows how to use my computer and I'm not going to be with them. How do I stitch a movie together for Windows XP?
Best Answer by Guthrieg hyde
Answered By 0 points N/A #131872
Hi? There is a lot of software out there that can help you accomplish this e.g. Easy Video Joiner, ZD Soft Movie Screensaver, SWF2Video. But if you are in a hurry you can use windows movie maker to do this. It is preinstalled into windows XP. Locate were windows movie maker is, then import the media files, make sure you know which one comes first. Then drag them to the time line in their respective order and save them in the most suitable format as one. I hope this helps you out.
Answered By 0 points N/A #131873
Hi Julia,
You mean stitch your 3-part-movie together and be viewed into a single, continuous movie? If that is, I’m sure you can. Having the fact that you have a Windows XP OS, it is easier to make this happen. First, save these 3 movies into the most accessible location, let’s see in your desktop. Name it into part 1-3 in order to identify which comes first. Second, click START and open Windows Moviemaker. Third, create new project and follow the instruction on how to add your three movies into the new project. Last, sure to have your project converted to movie file and burn into a cd/dvd.
