How do I synchronize audio powerpoint 2010?
I'm making a PowerPoint presentation and I would like to add audio files in it. I have PowerPoint 2010 and wav audio files. How do I synchronize audio PowerPoint 2010? I can't find add-ins for PowerPoint 2010 which the 2003 version has.
Best Answer by Keith J Harmon
Answered By 10 points N/A #183205
Dear Thomas,
There are different ways to synchronize the audio in power point 2010:
I'll walk you through how to deal with audio files in PowerPoint 2010.
1. Click on "Insert" tab then Audio.
PowerPoint 2010
Here you have 3 options (Audio from file / Clip art audio / Record audio ), Since you already have the audio files then choose Audio from file.
2. Choose the audio file(s) you want then click insert.
Audio from file
3. After you insert the audio file you will get the "Audio Tools" tab,
Insert Audio Files
Which include "Format" and "Playback" tabs,
* In "Format" tab you have different controls like changing color, shape and background.
4. Click on "Playback" tab,
Changing Colors Audio Tools
– Next to Start, you can choose,
Automatically –> to play the audio automatically with the presentation preview but it will stop after the first slide.
On Click –> to play the audio on clicking on certain text or photo, etc.
Play across slides –> will play the audio throughout the whole presentation.
5. For more settings of the audio files,
Click the "Animation" tab, then "Animation Pane",
Animation Pane
6. Double click the audio file or choose "Effect Options".
Animation Pane
7. This will open a window with all the settings of the audio file.
Play Audio Effect from beginning
– In the Effect tab you have control over the sound file itself. You can choose to start from the beginning of the audio or choose the specific timing you desire and when to stop playing it.
Play Aodio Time
– In Timing tab:
* Star –> On click (then you choose the trigger on which you click to start the audio)
With previous (to start with the previous slide)
After previous (to start after it)
* Repeat –> If you want it repeated.
Note: If you want to add different audio files to different slide then you have to do this process separately for each slide.
I hope this was helpful.
Answered By 0 points N/A #183207
According to your question, please follow the procedure below:
To insert an audio file in PowerPoint 2010, first you have to click on the insert tab of the ribbon. Then under the audio button on the right side of the ribbon, click the drop down button and then select the Audio from file option.
That’s how you can do.
Good Luck.
MS Powerpiont 2010
