I have a new Motorola moto g android phone that I would like to use for backing up my contacts from Nokia C3. The Moto g does not have a sd card slot save for the internal memory capacity. I need any simple method to transfer these contacts without using my sim card as the number of contacts has already surpussed the limit I can transfer at once. I would also like to do this without much heck as sim card method will force me to transfer by bits which I want to avoid at all cost. Can someone help me with an idea on how to go about this? Thanks in advance
How Do I Transfer Contacts from Nokia C3 to Moto G?
You Can Copy all your contacts to the memory card than connect it to the computer and copy those contacts to the computer.
You can even directly copy those contacts to the computer with the help of Nokia PC Suite Or Ovi Suite.
Once the contacts have been copied you can connect your moto x to the laptop/desktop and copy the contacts to the moto x.
Once contacts have been copied to Moto x you can go to contacts import from the specific folder you have copied the contacts.
Or you can update the contacts to your Gmail account from computer after copying from Nokia C3.
And than use that Gmail account with Moto x the contacts will be updated.
If it doesn't show up than you might have to open contacts in Moto x and there is an option for contacts to display in that choose all contacts.
