How do I turn on Closed Captioning on Direct TV?
Hey everyone,
I want to know how I can use the subtitles in the same way as Closed Captioning on Direct TV. Someone, please help me in turning on this feature.
Hey everyone,
The introduction of Direct TV has made it easy for the users to read Closed Captioning. You can use the subtitles feature as the same as Closed Captioning. You have to follow the steps to turn on Closed Captioning on Direct TV.
1) You will find a yellow button on your Remote Control. Press it.
2) There, you find the Direct TV Subtitling option.
3) Navigate to that option using the arrow buttons and press the Select button.
4) After you do this, Direct TV Subtitles will appear on the Screen.
Notifications
