How Do I Uninstall AVG PC Tuneup Trial?
Hi, I have installed the trial version of AVG PC TuneUp sometime before, and I am regretting it now as I cannot delete the application. Can anyone advise me how do I uninstall AVG PC TuneUp trial?
To get rid of the software, follow the below mentioned steps:
• Right-click on the shortcut icon of the software and click on Properties.
• Press the Find Target button, and then click OK.
• Locate the ‘Uninstallmanager.exe’ file and launch it to automatically remove the application.
• Remove the AVG PC TuneUp by doing right-click on it and selecting Uninstall.
• Click Yes in the next dialog box that appears.
• Click yes to restart the computer.
• Search for any AVG TuneUp remains and delete it from everywhere. If the above procedure does not succeed, try AVG PC TuneUp remover.
• The download link is:
 http://www.avg.com/filedir/util/TuneUp_Remover.exe
It will remove the AVG PC TuneUp and TuneUp Utilities completely from your device.
