How Do I Update Chrome Browser On Windows And Android?
I have Google Chrome as my default browser but I didn’t know how and when it gets update or do I have to do it manually? If the process is manual, kindly help me on how do I update Chrome browser on Android phone and Windows PC?
Answered By 0 points N/A #111175
Following the method to update your Google Chrome application on both the devices:
1. On Windows
a. Open the Chrome Window.
b. Next, go to the Menu option at the top right corner.
c. Select ‘About Google Chrome’. You will see it either directly, or click on Help > About Google Chrome.
d. If you have any latest or pending update, it will start automatically.
2. On Android
a. Open the Google Play app store.
b. Navigate to My apps from the menu at the top left corner.
c. Tap on the Installed apps.
d. Now, select Chrome from the list, and press the Update option manually.
e. Accept the licence conditions and the app will get update.
