How do I update delivery order template html?
I have designed a delivery order template html but I can't update it with new items. How do I update delivery order template html?
Hi Cohen,
In your template put some generic key words like for item name keep “**ItemName**” and on displaying it replace this text with the item name. Same thing can be done for other attributes on your template like Date, Customer name. If you want to display more than one Item then you have to use a repeater or list view.
Thank you
What techniques you use to design delivery order. The code must contain the elements for updating in website. If you are using any database then you can also need to update it. There are so many things that you need to make before you think of updating your html page.
Smith Thompson
