Bersh Roman
30 points
Posted on - 06/23/2012
When I try downloading some apps a message says that it is incompatible with my itouch and that I need the next version. My itouch is a 3rd generation itouch and I have a 4.2 os. Some games need a 4.3 os and some say it needs a 5 os. How do I upgrade my 4.2OS to a 5OS?
Hi
I will do this for you in very short time. This problem is really easy and solvable. You only need to download the original software from the situation and however you can find what you are doing your internet connection should be very fast and quick. Your computer should be very fast and accurate for this situation and how can you do this. This is not available for you how you will be able to do this when you are not allowed to do this and how will you find the solution of this problem and you will get the problem back into your mouth. Hope you like this answer and hope to get back very soon. I have solved this issue for you in very short time. Thanks.
