annie nje
10 points
Posted on - 10/14/2012
I have a touch screen PC that's running on windows XP & want to inquire do I need to upgrade touch screen drivers to ensure normal operations of my PC without it malfunctioning because of a missing or outdated driver? Anyone familiar with XP program touch screen?
How do i upgrade touchscreen drivers for PC using xp?
Your touch screen problem is not only a problem with the driver, I think it's a touch problem as well. However, if you think it is a driver problem, you can set up the upgraded version of Windows. I think you can solve this problem.
Good luck.
What is name of your touch screen’s manufacturer? I think they can provide you the latest driver. Search in their website or send them email for updates. If you want to do it by yourself then these web pages can facilitate mostly.
http://support.elotouch.com/Download/
http://www.driverscape.com/download/optical-touch-screen
For other sources of drivers, search in the Google with your device name.
