How do I upload files on Google Drive?
Hi fellow Techyv members.
I plan on using Google Docs, Google Drive to be specific.
How do I upload and share my JPEG and MPEG files?
Would it work on a Mozilla Firefox browser?
Do I still have to register with Google?
Best Answer by Sharath Reddy
Answered By 0 points N/A #198579
Hi Dorethadhoward,
Good day, I want you to go to the link drive.google.com and login the necessary information in order for you to access your drive, If you don't have an account for google drive, you can have one and the registration link is below the send button on the login screen of the drive.google.com, after which you will be transferred to your drive, to upload, press the red button that has the upload label and save it.
Answered By 5 points N/A #198581
Yes you can upload your files on Google drive while using Mozilla Firefox browser.
You need to first register with Google to get a Google drive.
Uploading files on Google Drive:
  • On the Google Drive site, create your own profile or log in with your email and password.
  • Click on the red “Upload” icon in the left column of the Google Drive page you in.
  • Click on the “Files” button and double click on the file you wish to upload.
  • Confirm the upload settings and click “Start Upload.”
  • You can view your uploaded file in the upload box which is to the right of your screen
Sharing files on Google Drive:
  • Go to the site drive google.
  • Check the box next to the file or folder you wish to share.
  • Click on the Share icon
  • Choose a visibility option you prefer
visibility options
  • Type in the email addresses of the people you want to share the file with in the text box below "Add people." You can add a mailing list, a single person, or choose from your contacts.
  • Choose access level from the drop-down menu which is next to each collaborator: "Can view," "Can comment" (Google documents, spreadsheets, and presentations only), or "Can edit."
·         Click Share & save.
Answered By 590495 points N/A #139702
Yes, it will also work on Mozilla Firefox as well as with any other web browsers as long as you have your Google account there will be no problem using it.
The easiest way of using Google Drive is to create a Gmail account first since this is the easiest way of navigating within your account. After that, using your Gmail account, sign in to Google Drive. Once signed in, you will then be redirected to the Google Drive page which lists all Google Documents you have associated with your Google account.
Click on the Create button and then select Folder if you wish to create a folder, for example. Give a name to your folder and then hit Create. Click on the Upload button located next to Create button to upload files.
You may also upload a whole folder if you like besides uploading files to your Google Drive account. To make all tasks easy, download and install Google Drive to your computer for instant synchronization between your computer and your Google Drive account. To understand it better, watch “How to upload files and documents on Google Drive | tutorial by TechyV”.
[video:http://youtu.be/klqrs1XHtcQ]
