How do I use Autoconfig in a multi node system?
Which user mode should log in while using Autoconfig in a multi node system? How can I confirm whether the Autoconfig is enabled or not? Please help me with a list of the components of Autoconfig.
If the below header is available on the top of files then this means Autoconfig mode is enabled
# This file is automatically generated by AutoConfig. It will be read and
# overwritten. If you were instructed to edit this file, or if you are not
# able to use the settings created by AutoConfig, refer to Metalink document
# 165195.1 for assistance.
You should login as ORACLE while using Autoconfig in a multi node system.
The following is the Autoconfig component list:
1.      Applications Context
2.      Database Context
3.      AutoConfig File Templates
4.      AutoConfig Driver File
5.      AutoConfig Scripts
6.      Context Editor
ELM_Steve
