How do I use the Intervideo windvd creator activation?
I'm having trouble with the intervideo windvd creator activation.
I have the trial version and the time limit is about to expire so I'm most likely going to upgrade to the full version but I'm not sure how this is done.
Is it automatic once I pay or does the website/company send me some type of additional software?
Best Answer by Clayton Freda
Answered By 5 points N/A #174312
Hi Walter,
For WinDVD creator there are 4 things that you need to prepare.
  1. Your registered email address.
  2. Your InterVideo password.
  3. Your Product serial Number
  4. The last 4 numbers of your credit card.
Once you got all the information mentioned above all you have to do is:
  1. Launch your free trial version.
  2. From the Menu up top of the software look for “Help”.
  3. Look for “WinDVD Creator Activation” then Click
A pop-up window will appear asking for the 4 information mentioned. After filling out the form press “OK”.
You now then have a full version.
Hope this helps!
By the way here’s the InterVideo’s official page.
You can find another product activation here and more support information.
Answered By 0 points N/A #174313
Visit the Lenovo Assistance website. This page contains the obtain for the free update of InterVideo WinDVD Designer coupled with all the changes that have been made from edition to edition.
Basically choose the weblink noticeable "wc301231u.exe." A screen will crop up providing you an alternative to obtain the software.
Just basically click "Preserve File" to preserve the record.
Once stored simply choose the program to start the setup. Click "Okay" to give your PC approval to start the setup.
The program will instantly update your InterVideo WinDVD Designer program.
Restart your PC and open the program to view the update in action.
Answered By 590495 points N/A #346137
It depends on the program you are buying the license to and the developer. Sometimes when you activate a program or upgrade to the full version, the serial code or license code will only enable all features and you will be using the same program installed. Free trials are intended to be purchased and the program will disable on expiration.
Most programs, when you buy a license to activate to the full version, the license code is sent to your email address. There are also ones that will require you to create an account on their website and your license will be sent to your account. Whichever applies to your case, programs that are free trials are sometimes offered as free download with all features enabled.
On expiration of the trial period, some of the features will automatically disable and you have to buy a license to get back all the features running again. There are also ones that will completely deactivate the program on expiration of the free trial.
