How do I use ssrs print on avery labels 5160?
Any ideas on how to use SSRS Print on avery labels 1×2 with 5 columns and 12 labels? When I printed the report, only one column was printed. I'm using Windows Vista 64-bit. Thanks.
Dear Thomas Osborne,
To use SSRS Print on Avery Labels 1×2 with 5 columns of 12 labels and make all the columns print, its software has a very useful tool in the printing area which is called scaling. Try to scale your printing area to cover all the required columns. For example, reduce the scale to around 70% as a trial and print. If all the columns still does not print, adjust the scale again, and so on, until you get all the columns to print.
Another method is to change the printer properties in Control Panel in Windows. Choose the size of label you want to print on and click apply.
Hope to be helpful
Don Muench
