How do i use stereo speaker for the computer
How do i use stereo speaker rather than computer speaker.
Please help me on this.
Thanks,
Best Answer by lee hung
Answered By 75 points N/A #117705
Hi Jack,
This is possible. I use stereo speaker on my coin operated PC here in philippines and the result is good it has more power especially if you play MP3, MOvIES Etc. All  have to do is to assemble an amplifier depending on the wattage you want for your computer. Amplifiers are available on the electronic store. You also need a power supply for your speaker and amplifier in order to work. Just like in the club they are now using amplifiers to run their music from computer to the big speakers. Make sure you also have a connectors for this. Please ask assistance on the electronic shop ask what the amplifiers available and the wattage. Ask what is the supply and warranty. Some of this electronic parts don't have a warranty, you should test it before you buy it. Here in the Philippines we don't have a US brand here especially on the amplifiers and speakers all in taiwan and china. If you have questions in future you can post it here.
Tony Stevenson
Answered By 15 points N/A #117706
You can use stereo speaker on your computer if your audio controller or sound card supports it. Some sound cards can only support a minimal setup while others can support a 5.1 setup or even better. Most new motherboard have integrated sound solutions that can handle this and a discrete sound card is not anymore necessary. Not unless you need to do some really complicated sound related applications. Once you have your stereo speakers, just connect it to your computer's audio port/s and it should work. If you would like to setup a better sound system on your computer, just follow the motherboard manual's instructions on how to get the sound system connected to the computer and you're good to go.
Answered By 0 points N/A #117707
you mean stereo speaker amplifier it same to use computer speaker  install your audio driver and connect to the pc.
