How do I view PS files for iPad?
Hi.  Can someone help me out?  I have the 64 GB Retina Display WiFi + Cellular iPad that has the Dual-Core A6X with Quad Core Graphics Chipset and iOS 6.1.  Is there a way I can open PS files for iPad?  Any help would be much appreciated.  Thank you.
Best Answer by Leland L Olson
Answered By 40 points N/A #139576
Hey,
Viewing Ps files has been a great challenge for many users. To view it requires installation of a desktop application that can read documents of this kind.
  1. You can convert the PS file to a PDF document using PDF creator or Ghostview.
Using PDF converter:
  • Download and install PDF creator
  • During installation check the box Associate.ps to PDF converter
  • Double click on the .ps file to convert to PDF
  • Open the PDF using Acrobat reader.
  1. You can also directly view it in your browser on viewer page.
  2. Its possible also to convert the PS files to PNG images.
Answered By 10 points N/A #139577
Greetings Dorethadhoward!
I don't think there are applications in iPad which allows you to view or open PS files but you can view or convert this PS files of your's using a website. Here is the link of the website I have mentioned. https://www.docspal.com/viewer. In these website you can view or convert several file formats such as ps, psd, tiff, word, powerpoint, images and other. Visit their site to try and see the features they offered. I hope this will help you about your problem. Thanks
