How do I write cd/dvd in Windows 7 operating system
I need to write a some files in dvd and cds and for this I need to know how to do that. So far I have known that windows 7 operating system does not need any external software to write cds or dvds. should someone know about this issue please help me out and I will be real grateful.
Evin Gizmo
Best Answer by Tunacao_Caaron1
Answered By 20 points N/A #117365
Hello Evin!
Burning a CD is not much difficult now. There are many software to burn the CD, Nero is one of the leading software among all.
As you have already mentioned above that you have Windows 7 so there is no need of any software to burn a cd.
In the following steps, you will learn how to burn CD in Windows 7.
1. Make a new folder and paste all your files there which you want to burn.
2. Select all files the files and click on the Burn button at the top of your window.
3. A new window will open in which you can see all your files, you want to burn. you can add or delete files from here.
4. Click on the Burn to disc button on the top of your window.
5. Once you click on that button,, it will then make sure whether you have inserted a blank CD/DVD or not. It will also give you option to write the name of the CD and to change the writing speed.
6. Click on next at the right bottom of the window.
7. It will burn your disc. After burning click on Finish button and you are succeeded in burning your CD/DVD
Thanks
Answered By 40 points N/A #117367
Hi there ,
I think you are having trouble with writing CDs or DVDs . There are many softwares both free and paid.
I suggest using NERO , it's the best , has better error handling techniques and very user friendly and can handle bulk writing easily and precisely .
Either download it or there is a Roxio easy CD creator which is available in the internet ,
Initiate all your downloads through filehippo.com because i feel very comfortable using it.
If you want to create CDs or DVDs in your Windows 7 itself follow my steps :-
1. Insert a blank CD or DVD .
2. Open the CD drive in computer and you can see it empty ,
3. Copy paste all the files or folders which you need to write to the disk ,
4. You can see burn CD or write CD at the top click on that and follow the steps.
Answered By 20 points N/A #117368
Burning files using Windows 7 was very easy. Thanks for your response,  Tunacao_Caaron1 . I just copy the files in the new windows of the CD driver > right> burn files. Done. Very easy. Thank you very much.
