How to do IPv6 bounceback email test
For checking IPv6 bounceback email test, I have sent mail to [email protected] but didn’t receive any instant reply; Is there any way to test the same.
HI THERE,
For resolving this issue trouble shoot IPv6 issues,
Identify your IPv6 address, browsing connectivity, Test PMTUD. Test your e-mail server connectivity, web mail, Test FTP access and NTP access, Bandwidth connectivity and performance also check out open ports and if problem is not resolved then here is a site
http://emailverifier.software.informer.com/
it is one of the good site for testing IPv6 mails.
Dear Allison Davy,
There are some things you can do. Actually bounces are typically going to be sent to the envelope sender. It means sending the mail from [email protected] is using your failedmails account is probably your best bet.
You can try these headers too:
Reply-To: [email protected]
Errors-To: [email protected]
Return-Path: [email protected]
Thank you.
