yumimakel
Posted on - 11/11/2011
I have hundreds of identical music data in my iTunes collection and it cannot seem to identify the authentic ones.
I know that I can remove these multiples one at a time, but is there a more efficient way within the program that I can use to do an automatic massive removal of identical music data?
Jackman
How to do massive removal of identical music data in iTunes?
The is actually an easy and effective way of dealing with your problem without having to remove them one by one and then organizing because this could be so tedious. You may download a plug-in that is able to delete duplicated music in iTunes in an automatic way. To download it visit www.RinseMyMusic.com. After downloading the latest version you will have to scan using the Find duplicate feature, through all your music library to identify all your duplicated iTunes. Next it allows you to choose to delete all the duplicates automatically or tagging the duplicated music with the word 'duplicate' then deleting them on your own. I hope this helps you out.
