How to do multiuser task in windows-7?
Click Start, Go to Control Panel.
If you are using the Classic read, click the icon labelled User Accounts. It's sometimes in the midst of AN icon of two cartoon people. If you are using vista and Windows 7, click the Add or remove user accounts link. This should lead you to the Manage Accounts screen, which is able to permit you to change your user name by assigning a password and changing the end user access settings.
Click Create a new account text under the big box displaying the current users.
Label the new account with the suitable name. Offer provide user account a name that accurately describes what it'll be used for. For example, if one account is for adults and another is for kids, label the new account Kids. You'll be able to additionally produce two separate accounts for home and business related use.
Select the account sort. There are two choices here, a standard Account, and an Administrator Account. A typical Account is able to access programs and install and take away programs, however won't be able to create changes that may affect all of the users or which can jeopardize the protection of the PC. Administrator Accounts have complete control over the computer but, it is going to need password verification, unwanted alterations to the system.
Add a password to the account by clicking on the required account on the Manage Accounts screen. Click on the Create a password link and enter a password into the field. Click the produce password button to finish the process.
