How do nitro reader differ from any other PDF reader?
Hi expert,
I am confused of using a pdf reader. I have got many kinds of files including pdf. One of my friends suggested me to use nitro pdf reader. But I don't know about it well. How do nitro reader differ from any other pdf reader? Please, tell me in detail as I can be sure of using it.
Thanks
Best Answer by Jose D Dunn
Answered By 45 points N/A #148524
Hello there Elijah,
Nitro PDF reader is the best PDF reader of all. They offer a lot of features like comments, bookmarks and etc.
It can let you create quick signs for your PDF and this reader also is very simple and easy to memorize.
You can also create PDF with this software. You can read its features of the article or you can download it.
Hope it helps you.
Regards Roland
Answered By 10 points N/A #148525
Hi Elija Hale Jandroo,
Nitro Reader is an amazing PDF creator or converter just like Adobe Acrobat XI but Nitro reader converts almost any file directly from the source. Nitro reader also integrates with other applications such as MS Office and create an option print to PDF just like doPDF and Adobe Acrobat XI. See attached pictures.
Here's how to convert files using Nitro Reader:
1. Open Nitro Reader and in the Home Table > Click Create From File.
2. Click Browse button to search file to be converted.
3. Click the Create button.
4. Nitro Reader will now convert the file.
5. PDF file was now create at source.
Done.
I hope this helps you about NItro Reader.
