I am using HP Photosmart Plus e-All in One Printer B210c with Windows XP, I would like to do OCR conversion of my scanned pages. Please advice about how doing Photosmart Plus OCR, do I need to install any additional software or plugins or drivers to get this done. Waiting for an expert solution. Thanks
How to do Photosmart Plus OCR
Greetings Zacharytyshawn!
I think the easiest way for you to convert you scanned documents whether PDF or JPG is the stall a software for OCR conversion. I suggest you use Adobe Acrobat 9 or the latest for this. Here is a link which features adobe acrobat 9 about Scanning & OCR.
https://acrobatusers.com/tutorials/scanning-and-ocr-beyond-basics
I hope this will help you in your problem.
Best Regards,
Jose D Dunn
In order to resolve this problem, you would need to go to the technical documentation of your HP Photosmart plus all in one printer B210c from the HP website. All your technical concerns will also be addressed by going to your local HP service center for technical advice and concern.
