How to do SEO Safe Point Determination?
I would like to determine a safe point where a page is acceptably authoritative, can create a right impression, attractive and fast enough to serve my consumers.
I could create a beautiful graphical page or a simply presented page with no graphics or vice versa.
Can anyone help me finding the best way?
Best Answer by Edmund Joseph
Answered By 0 points N/A #83640
There are several applications available on internet to serve your purpose. And most of those applications are quite capable of customized SEO solutions. You can sit back and relax and can use built-in features as well.
Example of such an SEO tool is "SEO Elite".
Try it and I can tell you for sure that you will find it really helpful. It will optimize your website automatically.
James Hoffman
Answered By 5 points N/A #83641
Hi there user:
You may go simple for your page. But you must make sure about the ‘what you want’ information. Well keywords to get the related terms, and the most important, to get a huge volume of visitors or searchers.
Make a wide list of your terms that you conclude are searchable via Google Search. Now create a spreadsheet for these, and start to input data. This is a simple way of manual monitor to your progress to fully understand its flow of success.
Now setup your desired SEO plug-in. SEO is automatically in progress, but you can still monitor and compare your data whenever you want.
Thanks for your post.
Best regards,
