How to do solidworks to artlantis import?
I need to import my 3d works created at solidworks to artlantis. If to say exactly- to Artlantis Studio 4.1. The version of Solidworks is SolidWorks 2010 SP0 18.0. Is it possible? If yes then how can I do that? I will be thankful for any help.
Best Answer by Marvin M Calderon
Answered By 55 points N/A #167518
Hello Palph V Thomas,
                  If you want to integrate Solidworks(2010 SP0 18.0) with that of Artlantis Studio (4.1) you can easily integrate the file of both the software. For that purpose all you need is to use a third part software for importing or exporting of any thing between them. I am sending you a link from there you can get the software so that you can integrate both the things with you.
http://softwaretopic.informer.com/import-solidworks-to-artlantis/
Answered By 0 points N/A #167520
Hello Ralph V Thomas,
          To integrate both files of Solidworks 2010 SPO 18.0 and Artlantis Studio 4.1, you need a third Part software likes as CAM-TOOL CATIA V5.You can be edited easily with this file and integrates them. I give you a site Link where you get the software and integrate both file easily and enjoy your work.
