How to do Windows7 Repair in Two Folder.
Asked By 5 points N/A Posted on -
Hello,Friends
I have Windows 7 and (Dual Core) system. After Fail my windows registration i do re-install my Windows in others folder except 'C' Drive. So there two folder system in Windows when start  and select between one to continue. I can't remove one.
Hope you Understand,Have you any solution to me.
Answered By 0 points N/A #96323
Solve
Hello Mr. Sibabu
I read your problem. But  I Think this is not very critical problem. Now I try to give some workable solution for your problem. Please read the below solution and work step by step then I think you will cover up the problem
If you want to cover up the first you have to re install your windows. First you put your disk into DVD or CD drive than restart your computer then you have to go to boot and choose DVD or CD drive [which you have or where you put your disk] then you find advance option and go there, then you see a table. In the table you see that there are written ‘C drive, D drive, E drive, F drive ’then you select the drive where you install your windows and select “Format” then again select C drive to format then start your installation. If you do that you don’t find two folder system in Windows.
I think now you understand. If you do this process you could not find that and do not have to select you can continue without selecting.
Thanks from
Arafat hossain
