I just want to know if how to do word count on adobe reader? I want to record the words that needed to be key in or encoded in a specific word file I need to monitor the word by word count for some reasons, can you give me a solution regarding this issue? Your suggestions and opinions will be much appreciated.
There are couple of ways to do this. You can either download and run your own word counter plug-in or import the document into a word processing program and you can automate the process. For the first option, you can download word counter using the following link:
If it does not work, try to look for Word program that can import your PDF files then use the a word counter software. Here is a video from YouTube that teaches how to get a word count for Microsoft Powerpoint, maybe you can grasp some ideas from it.
Hello Vanessa, To count the no. of words in your pdf document, Buy a specialized word counting software, like ANYCOUNT https://www.anycount.com/pdf-format
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
